Activity › Forums › Adobe After Effects › Motion Tracking Question
  • Motion Tracking Question
    Posted by Matt Deloach on September 18, 2013 at 2:47 pm
    Hey Everyone,
    Instead of recreating a similar animation in Cinema 4D or the like, I was wondering if anyone had a fairly simple solution to adding textures/icons to an existing animation I found on vimeo…
    https://vimeo.com/52618280
    What would you guys recommend the simplest solution would be to adding texture “tiles” to each face of these cubes? I looked into trying the 3D camera tracker in AE, but it simply doesn’t track the motion well enough or returns “analysis solve failed.” after analysis.
    I’m fully aware that I could add a tile to each cube face manually and keyframe everything with a camera or null object, but I’m wondering if anyone is aware of something far less tedious. Even paying for a plugin is an option if you happen to know of something that exists. I currently have both AE CS6 and CC installed.
    Thanks in advance,
    Matt
    Roland R. kahlenberg replied 13 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 23, 2013 at 9:02 am
    It’s an AE template. WHy not just purchase the template and be done with it?
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
