Activity Forums Adobe After Effects Motion Tracking Question
  • Motion Tracking Question
    Posted by Ionut Anton on February 17, 2012 at 11:23 am
    Hy guys,
    I have i bit of a situation regarding an already tracked footage.
    After i tracked the footage, i applied the data on a null layer.
    After applying it i noticed some wrong tracking points, which i fixed.
    How do i attach the corrected tracking data on the null layer (which already has the first set of tracking data), without having to analyze again?
    Thank you in advance,
    Toni
    Ionut Anton replied 14 years, 6 months ago 2 Members · 2 Replies
  • Frank Brown
    February 17, 2012 at 2:48 pm
    Select your Footage -> under “Tracker” panel choose your “Current Track” you want to fix->
    -> on the time line go to points you want to fix -> fix values (re-edit positions) -> re-apply Tracker to the footage.
  • Ionut Anton
    February 19, 2012 at 9:33 pm
    Thank you Frank
