Activity Forums Adobe After Effects motion tracking problem
  • motion tracking problem
    Posted by Joonas Kuivjõgi on January 6, 2010 at 11:23 pm
    Hey! I’m pretty new to After Effects, so I’m having some troubles with motion tracking that seem easy to fix but I’m clueless how to do it the “easy” way.
    Ok, I did perspective corner pin motion tracking, applied the data to new layer. Everything was perfect until the layer started “rotating” by itself. I tried to solve this by trying almost everything under “Transform” option but no help.
    Couple screenshots to show exactly what I mean..
    1)this is how ran at start and how it should run – https://tourneycpm.mrlazyinc.com/files/users/emir4nt/Capture_065.jpg
    2)this is next frame (wrong way) – https://tourneycpm.mrlazyinc.com/files/users/emir4nt/Capture_066.jpg
    this lasts for about 70 frames so moving the layer manually would be pretty time consuming…
    Thanks to advance.
    (Sorry if this thread already exsists somewhere, I’m in a hurry)
    Joonas Kuivjõgi replied 16 years, 7 months ago 2 Members · 2 Replies
  • Thomas Horne
    January 7, 2010 at 6:35 am
    My thought is that maybe you mixed up which corner pin tracker goes to which corner? It looks like point 2 became point 3, etc.
    This should be pretty easy to check just by following each tracker and seeing if it suddenly jumps to the wrong corner along with the rest…
  • Joonas Kuivjõgi
    January 7, 2010 at 7:33 am
    I ended up switching corner pins by myself and re-tracked motion.
