Activity Forums Avid Media Composer Motion Tracking – Mapping to corner pins
  • Motion Tracking – Mapping to corner pins
    Posted by Alex Bond on April 20, 2009 at 9:52 am
    I could be thinking about this in the wrong way but is it possible to tell Avid to map corner pins to a motion track?
    Do I have to manually drag the corners onto each point of the motion track? Is there a better/right way?
    I’m using Avid Media Composer and trying to put a video layer onto the wing of a Satellite as the camera zooms into it. I’m aware After Effects might be a better tool but I think Avid can handle this and I want to retain the capability of editing audio.
    If someone can explain it to me in a way other than the way ‘explained’ in the manual, which I can’t follow, I’d be very grateful!
    Alex
    Alex Bond replied 17 years, 4 months ago 2 Members · 2 Replies
  • Grinner Hester
    April 20, 2009 at 3:12 pm
    Avi’s tracker is not great so you’ll often have best results with just one tracker. You can add one per corner though. Don’t confuse it’s corner pin effect with how it works in AE. It’s just a shape effect in Avid.
    I’d use a PIP effect, add one tracker than shape as needed.
  • Alex Bond
    April 27, 2009 at 4:06 pm
    I’ve given it back to our graphics guy – looks like I was gazing really!
    Alex
