Activity Forums Adobe After Effects Motion tracking jitters
  • Motion tracking jitters
    Posted by Ken Pugh on May 11, 2012 at 7:43 pm
    I’m using motion tracking to tie text to objects in a moving frame.
    I seem to get a much smoother track in Apple Motion – After Effects tracking seems to ‘jitter’ the text between one pixel and the next, giving a small random ‘shake’, particularly when the frame is fairly still. It’s like it’s constantly moving back and forth between two pixels (tried turning sub pixel off). I find I’m having to do the track in Motion and import the text into AE for the compositing and masking (as I much prefer these tools in AE). I’ve tried many solutions, played with all the tracking options, tried the smoother, tried manually adjusting frames a pixel back and forth (that way madness lies) but no luck. Is there a technique for this I’m missing?
    Cheers, Ken
    Tudor “ted” jelescu replied 14 years, 4 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    May 11, 2012 at 8:10 pm
    There are many tutorials on AE tracking. I would recommend checking out Mocha (free version with AE)- it does a superb tracking job on most clips.
    One question regarding your footage- is it interlaced or progressive?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Roland R. kahlenberg
    May 12, 2012 at 12:47 am
    As Ted has suggested, mochaAE/mochaPro should provide more powerful tracking options.
    A common technique to deal with jittery tracks is to enlist separate tracks and then average their results prior to applying a single data onto a layer.
    FWIW, the beauty of mocha’s products is that you can track a plane and then export out multiple track points within the plane, without having to re-track each point separately.
    Scenarios that lend themselves to such a workflow is the removal of markers that cannot be keyed or are required as targets for paint work AND when a single track doesn’t provide a proper solution.
    Take a look at the first clip of this video for an example of using markers as guides for both tracking a perspective plane as well as guides for paint – Using Tracker Markers as Guides for Paint.
    All I had to do was to perform a single track of the plane where the markers were placed. Once the track was done, all I had to do was to move mocha’s Surface Area (to select either an area or a marker)and export either Perspective or Transform data.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Ken Pugh
    May 12, 2012 at 9:22 am
    Thanks for both these replies – I’m using interlaced footage – and to make matters worse, some of the clips are being re-sized…. however Motion still does a smoother job. I’ve been looking for a way to manipulate the tracks, and average them out, as this felt it could be a solution – sounds like Mocha might be perfect, I’ll explore this further, and check out the tutorial.
    Many thanks, Ken.
    May 12, 2012 at 10:06 am
    Your AE tracking issue comes from the fact that your footage is interlaced. De-interlace and track again, I bet AE will track just fine.
    Tudor “Ted” Jelescu
    Senior VFX Artist
