Activity Forums Adobe After Effects Motion Tracking Issues?
  • Motion Tracking Issues?
    Posted by Vladimir Lester on February 2, 2015 at 1:34 am
    Hey guys!
    I’m fairly new to After Effects CC and I’m having a bit of a problem.
    The effect I’m trying to pull off is having the text staying stationary through a moving video.
    I’ve watched many tutorials and I just don’t get it. No matter whether I track it in the default tracking program or Mocha, it slides up or shifts a little bit as the camera moves.
    Someone please help me!!!
    Lex
    Jeff Kay replied 11 years, 7 months ago 3 Members · 3 Replies
  • John Cuevas
    February 2, 2015 at 6:29 pm
    Hello Lex. Could you please post the video to Vimeo or the Cow, so we can take a look at it and see what issues may be encountering.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Vladimir Lester
    February 4, 2015 at 1:16 pm
  • Jeff Kay
    February 6, 2015 at 6:01 pm
    There is always some adjustment to motion tracking paths. If what you’ve tried has gotten pretty close, that might just be where you are at.
    Also worth noting is that it really helps if the footage was shot with it in mind to make sure that the footage’s camera movement was perfectly smooth.
    Alternatively I’d try creating a camera in AE that rotates along with the footage’s movement (leave the footage as a 2D layer) and then you can place in the 3D text as a 3D layer and leave it stationary. If the camera’s movement matches, then that should work.
