Activity Forums Adobe After Effects Motion Tracking data is not transferring to Null Object properly…
  • Motion Tracking data is not transferring to Null Object properly…
    Posted by David Anthony on February 20, 2010 at 7:07 pm
    I am doing a “light writing” piece for a church. I am tracking an LED pen light, setting the target to a null object, and using particles.
    My problem: The tracking data is fine. But when I set the target to the null object, the data is flawless for about half the word. I tried this with two different null objects (to see if I made a small mistake the first time) and the first one went too low on the screen, while the other one went too high and to the right.
    What is even more frustrating is that I executed it flawlessly once already and can’t understand what I am doing wrong now.
    Has anyone else run into this problem?
    Thank you!
    Harry Clegg replied 16 years, 5 months ago 3 Members · 3 Replies
  • Joey Foreman
    February 20, 2010 at 7:37 pm
    I believe this video tutorial addresses your issue. Check it out.
    https://vimeo.com/9208540
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • David Anthony
    February 20, 2010 at 8:49 pm
    Thank you, but no that doesn’t help.
    I just did it again successfully in a new project. Then I opened another new project for the next one I had to do and the null object is dragging from the tracking data again!
    I really don’t understand. Is this not a known issue? I have searched all over the place…
  • Harry Clegg
    March 23, 2010 at 4:33 pm
    I had a similar problem just now and it may well have been a pixel apsect issue, as Dave indicated. My footage was shot 720p on a Panasonic HVX200. Normally I capture (log and transfer) into FCP and then export a QT to AE. On this occasion I located the QT FCP created in the capture scratch folder and imported that into AE. With this source footage none of my tracking data transfers properly to the nulls and they don’t stick to the scene. I’ve just reimported the footage in the old way and everything works fine.
