Activity › Forums › Adobe After Effects › Motion Tracking and Green Screen in AE CS3
Posted by Dan Oster on May 11, 2009 at 10:27 pmHey all. I’m attempting to shoot a handheld piece on green screen. I want to “pin down” my digital background so that it appears to be fixed in place despite the camera movement.
I suspect I need to mark the green screen with physical tracking points to do this, but I’m not sure the best way to do that (how many, what color, etc.). Nor am I sure how to set up this effect properly in AE.
Any tips?
– Dan
Dan Oster replied 17 years, 3 months ago 6 Members · 21 Replies -
Brock Nordstrom
May 11, 2009 at 10:29 pmKeylight is usually the best choice for Green Screen.
and 1 tracking point should do the trick. A simple cross made in black tape should work. -
Dan Oster
May 11, 2009 at 10:58 pmThanks.
I’m more or less familiar with keylight. It’s trying to parent the background to tracking points that I’m new at. I found a good tutorial that seems to apply:
https://library.creativecow.net/articles/kramer_andrew/Set_Extensions/video-tutorial.php
However, will motion tracking compensate for zooms?
– Dan
Tom Scott
May 11, 2009 at 11:39 pm“I want to “pin down” my digital background so that it appears to be fixed in place despite the camera movement. ”
I read the above line to mean that you want the background to remain static, “despite the camera movement”. If that’s the case, no tracking is needed at all.
Dan Oster
May 11, 2009 at 11:51 pmI’m sorry, let me rephrase. I want the background to move in order to compensate for camera movement so that it looks like the camera is panning around an actual set.
– Dan
Jim Dodson
May 12, 2009 at 12:12 amDan-
With respect to your question about motion tracking the camera’s “zooming”.
You will need to check “position” and “rotation” and “scale” in the motion tracker window, then when you shoot your greenscreen give yourself 2 separate tracking marks separated as far apart from each other as possible… but make sure that neither tracking mark ever leaves frame or is obscured by your foreground or your actors…
good luck!
Jim Dodson
8 Core Intel — Mac – OSX
Chris Buttacoli
May 12, 2009 at 3:57 amYou know what works great!? Post-Its! AE tracks squares nicely, and there’s no mess left on the expensive greenscreen. I typically use five around the actor. Any time the actor moves in front of a marker you will need to clean up in AE, but fairly simple roto work is worth the nice track. The only advice I can stress to you is to make sure you can ALWAYS see at least two markers at all times. This will ensure proper scale and rotation when tracking.
Dan Oster
May 12, 2009 at 4:12 amPost-Its! That is some great advice. I bet if I get them in a wild color I can key that out no problem. Thanks!
– Dan
Dan Oster
May 12, 2009 at 6:42 pmI think the camera motion will be fairly restricted–mostly just the jitteriness of a “handheld” cam that’s mostly stationary, with the occasional quick zoom. So hopefully a background that’s a bit larger than the screen will suffice.
Thanks for the input! This will be fun…
– Dan
Dan Oster
May 12, 2009 at 7:20 pmGood point. I can keyframe in a blur at that point if I’m really worried. But my background is 720p so I should have some wiggle room.
– Dan
Chris Buttacoli
May 13, 2009 at 2:46 amBTW, don’t try to “key out” the markers. Prior to keying, you should make a garbage matte around your subject, as tight as possible, which will eliminate the markers and allow Keylight to work faster.
