Activity › Forums › Apple Motion › motion tracking a clone layer?
Posted by Jeremy Wilker on January 24, 2010 at 6:08 pmIs it possible to motion track on a clone layer in Motion 4? I can’t seem to get it to work and I need to stabilize the track a second time if possible to control slow drift of the camera. Any ideas or tips?
Stephen Smith replied 16 years, 8 months ago 2 Members · 7 Replies -
Stephen Smith
January 25, 2010 at 3:55 pmJeremy,
I’ve never tried and took a look in the manual and this is what the Manual says:On page 1304 —- Cloned objects cannot be tracked.
Sorry, I’m not sure if that is the answer you are looking for.
Check out my Motion Tutorials
Jeremy Wilker
January 25, 2010 at 4:25 pmThanks, I didn’t find that when I searched the manual. Hmm… well, need another solution then!
Stephen Smith
January 25, 2010 at 4:30 pmWhy do you need to track a clone layer? Why can’t you track the clip itself?
Jeremy Wilker
January 25, 2010 at 4:42 pmI did track it and it is greatly improved, but we (for various reasons) have to take a hand held clip and make it look like a tripod clip. the tracking is good, but it still drifts a bit around the screen. maybe I’m doing it wrong but it seems a second tracker would lock it down just right!
Stephen Smith
January 25, 2010 at 4:57 pmOh, so you are using the Stabilize Behavior? If tweaking the settings doesn’t work and you want to do it again you could always bake the clip. This means you export it out and then import the exported clip and run the Stabilize Behavior on it. Hope this helps.
Jeremy Wilker
January 25, 2010 at 7:23 pmDOH! of course. I probably shouldn’t ask questions when sleep deprived. That solution will work just fine for this, thanks a bunch for illuminating me!
Stephen Smith
January 25, 2010 at 8:25 pm
