Activity Forums Adobe After Effects Motion Tracking a bottle spin!
  • John Cuevas
    June 12, 2015 at 12:55 pm
    I think you will need to use some sort of distort effect like CC Cylinder. You might also need to precomp your text first, mask in a precomp as the bottle turns to effect the final Cylinder effect.
    If you know C4D, it might be easier to just apply your text to a cylinder there, copy the AE camera to C4D, then rotate the cylinder. Then the text will disappear as it turns. Then you could composite it all in AE.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
