Activity › Forums › Adobe After Effects › Motion tracking 2 end points of a line, how?
  • Motion tracking 2 end points of a line, how?
    Posted by Scott Green on May 8, 2012 at 10:53 am
    I’ve just watched this video ‘Natural Fight (Find Perfect Shape) by Berkanism’ and I’m a little bit baffled by something that happens 11 seconds in, but I’m sure there’s a very simple answer.
    11 seconds in where the flower and tree connect with a line and 2 dots I imagine that motion tracking was used to map the dots to the flower and tree but what technique was used to map the ends of the line to the dots?
    I’ve seen this type of thing done before, mostly in 3D software, but in my head I’m slightly baffled by how to attach the ends of a line to 2 points in AE.
    Anyone?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Creative Multimedia Design Manchester | S©tt Green | Splurj
    Lyle Aspinall replied 7 years, 11 months ago 4 Members · 11 Replies
  • 11 Replies
  • Roland R. kahlenberg
    May 8, 2012 at 12:32 pm
    The Effect>Generate>Beam effect is used to create a line. The effect has two positions, each representing the ends of a line. Here’s an example of what I did with three renditions of the Beam effect – https://www.broadcastgems.com/MediaServer01/TrackingTest_PavementLeaves_01.mp4
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Scott Green
    May 8, 2012 at 1:05 pm
    Good stuff, I also found this tutorial for the beam effect:
    https://vimeo.com/28245408
    Thanks for the reply.
  • Scott Green
    May 16, 2012 at 8:57 am
    If you had 3 points to link 3 beams to, could you also links 3 points of a shape to fill between the lines to get this type of effect?
  • Scott Green
    May 16, 2012 at 8:58 am
    Here is a link to the animated version:
    https://media.smashingmagazine.com/wp-content/uploads/2012/05/rough_seas.gif
    May 16, 2012 at 10:58 am
    Was that done with Plexus?
    As to your Q, you can create an Adjustment Layer, set it to the top of your Timeline. Then apply Effect>Generate>Paint Bucket. Use the Fill Point and Tolerance properties to suit your needs. Take note that you will be able to apply multiple instances of Paint Bucket to color non-contiguous areas of the layers below you Adjustment Layer.
    You should take note that the Paint Bucket colors/paints an enclosed area defined within the RGB, Alpha or RGB + Alpha values.
    HTH
    RoRK
  • Scott Green
    May 17, 2012 at 11:06 am
    I didn’t realise that the Beam effect wouldn’t work in 3D space?
    May 17, 2012 at 11:25 am
    A 2D point can be made to follow a 3D point. With a 2D Solid with the Beam effect applied, you can have the start and end properties follow 3D Nulls or any other type of 3D layer.
    Place the following script in the Beam’s Start Point property –
    StartPointLayer=thisComp.layer(“Null 01”);
    StartPointLayer.toComp([0,0,0])
    Replace the text Null 01 with your own naming convention. Then copy the same script to the layer that is being used to represent the End Point of the Beam property.
    The script ‘hooks’ the said Beam properties to the top left of each Null, denoted by the values [0,0,0]. Therefore, by changing these values, you will be able to place your Beam points with precision.
    HTH
    RoRK
  • Mac Lanphere
    April 14, 2013 at 5:40 pm
    hi Roland,
    I’ve got a simple rig using your expression, and it works great, until the camera moves past the beam connection point in z-space–then the beam goes haywire (flips axes? not sure….)
    is there a way to avoid this?
    cheers
    Mac
    April 15, 2013 at 2:23 am
    Hi Marc, I’ve not faced such an issue and I’m surprised that it’s happening. My only thoughts are that if the point(s) is behind the camera, you can split the beam layer and manually keyframe the required property. See if this works.
    Cheers
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Mac Lanphere
    April 15, 2013 at 3:34 am
    I’m sure I can work around it (and I had the same issue with a similar expression from Dan Ebbert on a post from a couple years back)
    thanks anyhow!
    Mac
