Activity Forums Adobe After Effects Motion tracker trouble
  • Motion tracker trouble
    Posted by Chris Holland on July 7, 2008 at 9:00 am
    I am having a problem using the motion tracker which I have never had before. When I enable it I just get a black screen which means I have nothing to use as a reference to track.
    The only different thing I am doing this time is I am using a still image which I used an extract matte on. Could this have anything to do with this? And is there a way I can still tack this layer to the footage?
    Chris
    Peter O’connell replied 18 years, 1 month ago 3 Members · 3 Replies
  • Curious Turtle
    July 7, 2008 at 9:15 am
    Hi Chris,
    Are you trying to track the footage or your still image?
    Right-click on your video footage and choose Track Motion. Then change your “Target” to be your still image. In fact, I usually create a Null Object to store the tracking data, then use Parenting to match the move. I just find that gives me a bit more flexibility.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Chris Holland
    July 7, 2008 at 12:11 pm
    Hey Ben,
    Thanks for your help. I tried this and I managed to get the tracking data on to the layer. I can even see the tracking data at work on the layer by itself and it’s a perfect track. Yet when I look at the comp the layer does not move at all. Is this strange?
    Chris
  • Peter O’connell
    July 7, 2008 at 7:03 pm
    Hi Chris, you might be looking at the layer window as opposed to the comp window.
    Hope this helps
    Pete
    peteoconnell.com
