Activity Forums Adobe After Effects Expressions Motion Tracker to Brush Path
  • Motion Tracker to Brush Path
    Posted by Manuel Dugué on June 12, 2009 at 11:13 am
    im new to expressions. I’ve got a motion tracker, following some information in the movie and want to draw a line, that follows the tracker all the time. Begin should be the first feature center, end the actual feature center. Is there any way to do it?
    motionTracker("Tracker 1")("Track Point 1").featureCenter[0]
    gives me an error, wanting a Property instead of an array.
    Thanks in advance
    mnl
    Tony Pica replied 14 years, 6 months ago 3 Members · 3 Replies
  • Curious Turtle
    June 12, 2009 at 8:12 pm
    Here’s a way to do it:
    i) Track your footage and apply it to a Null.
    ii) Use the Write-on effect and use the pickwhip to link the Brush Position to the Null’s position. Job done.
    In fact, you could not bother with an expression if you didn’t need to. Just copy and paste the keyframes from the Motion Tracker (or Null) to the Brush Position.
    HTH,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Need help with your planar tracking?: Rock Steady : Successful Motion Tracking in Mocha & After Effects & Tracked : The Art of Motion Tracking in Mocha for FCP
  • Manuel Dugué
    June 15, 2009 at 12:18 pm
    that worked out very good. Just the performance is far behind the workflow i was hoping for (20 min of video).
    thanx
  • Tony Pica
    February 20, 2012 at 6:07 pm
    I’m looking to do a similar thing in a video, however I don’t know how to apply my motion tracking to a null object. I also don’t even know where to find the write-on and pickwhip.
    FYI this is the first time I’ve ever really used AE.
    This is the effect I’m trying to create:
    https://www.youtube.com/watch?v=UiezugBMHiU
