Activity › Forums › Adobe After Effects › motion track non video elements
Posted by Ben Wolfinsohn on December 25, 2012 at 10:50 pmcan you motion track a photoshop layer that is moving around to then allow other layers to follow it when parenting isn’t an option? or can only motion track a QT? cuz of corse could export out a QT then import it, then track it, but its kinda a pain to do it that way.
Mato Kokotic replied 13 years, 8 months ago 5 Members · 8 Replies -
Joseph W. bourke
December 26, 2012 at 12:30 amI would suggest that you use expressions – just using the pick whip to make the position of one layer follow another is quite simple and powerful. Here’s a quick rundown on the pick whip:
https://www.jjgifford.com/expressions/basics/pickwhip.html
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Ben Wolfinsohn
December 26, 2012 at 12:35 amoh yes. i know how to do that well. but i just needed to use the motion tracker to track moving pixels in another comp. so not possible then?
thanks!
Roland R. kahlenberg
December 26, 2012 at 1:16 amYou can pick-whip an Expression between two properties across two comps. The trick is to set your Workspace to display both Timelines.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
Ben Wolfinsohn
December 26, 2012 at 1:18 ambut is it true that you can only motion track movie files?
December 26, 2012 at 1:21 am[ben wolfinsohn] “but is it true that you can only motion track movie files?
“Yes. It’s unnecessary/additional work to track a still image. Parenting and Expressions are more productive and effective methods to achieve your desired results.
HTH
Todd Kopriva
December 26, 2012 at 4:15 amI’m confused about what you’re trying to accomplish. The point of motion tracking is to extract motion information from video—i.e., from a source about which you don’t already have the motion information. If you have an animated element in a composition, you already have its motion information, as keyframes and/or expressions. So why not just use that information that you already have? Why use an imperfect and indirect process like motion tracking?
After Effects team blog
Ben Wolfinsohn
December 26, 2012 at 7:21 ami bult a really complex movement by using a series of time remapped comps that i then needed to follow the end movement. and theres no way to follow the movement without eyeballing the final end comp. if i follow the comps that were used to build it then it would never be the correct movement.
Mato Kokotic
December 26, 2012 at 9:21 amIf you REALLY want to do it your way, you can always render your comp, import it and then motiontrack it…
