Activity Forums Adobe Premiere Pro Motion & Track Matte
  • Motion & Track Matte
    Posted by Dinadani on April 10, 2005 at 9:26 am
    When watching a certain video i noticed an interesting effect. Somewhere in the video there are white lines which seperate the video. Inbetween those lines (or a scaled up rectangle, i’m not sure) the video is being played at normal brightness, but outside those lines, the brightness is set lower. When using a track matte (and this tutorial: https://www.animationsforvideo.com/html/matteapp.htm ), this is a piece of cake. Using the same vid twice (track 2 and 3) and the matte.tga on track 4 with its reference to track 3, i managed to darken the video on track 2, while keeping the video on track 3 at its original brightness. I included two small white bars and the effect was born.
    But i wondered if i could do more with it. For instance, in the same video, he moves that effect around. The space inbetween the lines get bigger and smaller and moves around the screen, ‘highlighting’ different parts of the underlying movie. Now this is where i hit a wall, as i can’t get the matte.tga moving around. Matte.tga has the motion options, but no matter what i do, the matte keeps its same size and won’t move around, scale up, rotate etc. I figured this might have something to do with the matte actually being turned off (clicked the eye, ‘disabling’ track4, see the upper tutorial), but i’m not sure.
    I wondered if you guys know any way around this, or an alternative way of getting that special effect shown in that particular video. Thanks in advance.
    p.s. I uploaded a pic here ( https://www.wastedspace.nl/~dinadani/bscap018.jpg ), for those who are still unclear on the effect i meant.
    Steven L. gotz replied 21 years, 4 months ago 3 Members · 2 Replies
  • David J
    April 10, 2005 at 11:54 am
    Premiere Pro handles track mattes differently from earlier versions.
    To achieve a moving track matte, the matte and its motion must be in a separate sequence in PPro. Then use this sequence instead of the mask as the matte in the main sequence.
  • Steven L. gotz
    April 11, 2005 at 12:04 am
    You might be just as happy animating a garbage matte. Easier in my opinion.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
