Activity Forums Apple Final Cut Pro Legacy Motion to Finalcut settings
  • Motion to Finalcut settings
    Posted by Ellen Osborne on April 1, 2008 at 2:07 am
    I need to be enlightened. There has to be an easy way to do this. I’m making a little animation creating most of it in Motion 3. I want to take it over to Finalcut to do some additional editing. My question is, is there an easy way that finalcut can just pick up the audio/video settings from Motion? I can’t seem to make them match which means I have to constantly render. It’s driving me crazy. I always have the red bar. My Motion projects are 1920 x 1080, pixel aspect ratio: square, field dominance: none, 23.98 fps. I try to do all the same settings in FCP, then import the Motion project. but I still get the red render bars. What’s the problem?
    Jeremy Garchow replied 18 years, 5 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    April 1, 2008 at 2:12 am
    If you import a motion project, FCP will still need to render that project. If you export a Quicktime out of Motion that matches your FCP editing sequence, FCP can play that in real time.
    Make sense?
    Jeremy
  • Ellen Osborne
    April 1, 2008 at 2:44 am
    Yes that makes sense, but it’s a little disappointing. I was hoping they were friendlier, so I could easily go back and forth and not bother with the movie export. Oh well.
  • Jeremy Garchow
    April 1, 2008 at 2:57 am
    [ellen Osborne] “Yes that makes sense, but it’s a little disappointing.”
    Well, think about it. When you import a Motion project, you haven’t done any rendering of your material and FCP can’t playback that amount of data in real time. When you bring in a QT movie, that movie is rendered, flattened, and optimized for rt playback.
    Jeremy
