Activity Forums Apple Motion Motion to FCP Template Text Issue
  • Motion to FCP Template Text Issue
    Posted by Patrick Harper on November 18, 2010 at 11:35 am
    Not sure if this belongs in here or the FCP forum but here goes…
    I’m attempting to build a basic template in Motion for use in FCP.
    Everything works fine and I can open the template in FCP and then change the text within the template in the viewer.
    BUT! When I press return to start a new line of text I get a small vertical line, a bit like an “i” but without the dot. How can I change the template’s text content from one line to two without getting this line?
    Many thanks,
    Patrick
    Patrick Harper replied 15 years, 10 months ago 2 Members · 2 Replies
  • Mark Spencer
    November 18, 2010 at 1:47 pm
    You need to change the text layout to a paragraph with the size you want in Motion.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Patrick Harper
    November 18, 2010 at 3:08 pm
    Thanks, Mark.
    I just went back into Motion and added some blank lines under my original line of text.
    As long as I don’t press return when changing the template’s text content in FCP and instead just click on one of the new blank lines it works a treat.
    EDIT – Further investigation revealed it was an issue with the font (Gotham Bold) but the above fix was necessary anyway as client specifically requested that typeface.
