Activity › Forums › Apple Final Cut Pro › Motion / Titles
  • Motion / Titles
    Posted by Wayne Garton on July 3, 2011 at 9:47 pm
    Question 1 – I have motion 4 titles I regularly use on the timeline of FCP 3. When I edit these I right click and open in editor, save and they appear in FCP 3.
    I can open these motion 4 titles in motion 5, but how can I now use them in FCP X?
    Do they have to be recreated from scratch????
    Question 2 – If I open a “composition” in Motion 5 (that is .. one of the pre-designed titles like “atmospheric”), can it be published to FCP X?
    If not, how do I copy the animated backgrounds in a new motion document that can be used in FCP X
    Any ideas ????
    Cheers
    Wayne
    New Zealand
    Brendan Gibbons replied 15 years, 3 months ago 2 Members · 3 Replies
  • Brendan Gibbons
    July 3, 2011 at 10:07 pm
    From inside motion you can open both your motion 4 and 5 compositions like you say, and to make them reappear back in final cut it’s not entirely obvious I found.
    In Motion, select File / Publish Template
    To have it appear in FCP X you need to tick the box Publish as Final Cut Generator.
    Here’s hoping the simplify things and let us import Motion projects directly in FCP X like we use to be able.
    Cheers,
    Brendan
  • Wayne Garton
    July 4, 2011 at 1:27 am
    Thankyou Brendan. That worked a treat!
    You don’t happen to know the answer to question 2 do you ? (or perhaps that is the same answer as question 1)
    Cheers
    Wayne
    New Zealand
  • Brendan Gibbons
    July 4, 2011 at 1:50 am
    Sorry I didn’t make it clearer, but yes, the solution of publishing the template as a final cut generator applies to your question 2 as well.
    cheers,
    Brendan
