Activity › Forums › Adobe After Effects › Motion Tile with no seam?
  • Motion Tile with no seam?
    Posted by Robert Kornstein on June 19, 2014 at 2:13 am
    I’m trying to create a background of scrolling clouds. The Illustrator file is meant to scroll seamlessly, but both Offset and Motion Tile leave a small seam where the repetition happens.
    Here is how it looks right now:
    Is there a way to eliminate that seam?
    Autumn Nakamura replied 6 years, 5 months ago 5 Members · 6 Replies
  • Brian Charles
    June 19, 2014 at 5:33 am
    [Robert Kornstein] “The Illustrator file is meant to scroll seamlessly, but both Offset and Motion Tile leave a small seam where the repetition happens.”
    Depending on your specific needs, perhaps the easiest solution is to redo the original artwork to make it match at the left and right edges of the frame. That way when the image is offset the seam won’t be visible.
  • Robert Kornstein
    June 19, 2014 at 5:50 am
    It already does match, that’s what I was trying to say. The seam appears regardless.
  • Brian Charles
    June 19, 2014 at 6:02 am
    [Robert Kornstein] “It already does match, that’s what I was trying to say. The seam appears regardless.”
    That’s odd, I don’t get the same result when the sides match. Here’s a rough test I did with an ai file that’s the same width as the composition.
    7642_seamlessscroll.zip
  • Kevin Camp
    June 19, 2014 at 5:10 pm
    it could be due to the artwork not filling the art board fully in illustrator (thus leaving a slight edge).
    what if you drag that ai file onto the make comp icon, then set the comp to be 2 pixels less wide (to trim any bad edges), then take that comp into another comp and try offset/motion tile.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Alan Knox
    August 12, 2016 at 7:46 pm
    My *guess* is that your Illustrator file is something like 394.73221 x 599.8322 instead of a crisp 395 x 600. First rescale (taking off constrain proportions) to the crisp number, then re-crop your artboard.
  • Autumn Nakamura
    April 8, 2020 at 7:52 pm
    I just encountered this same issue using Offset with a seamless .ai file, but only if that layer had “continuously rasterize” selected (which mine did because it was scaled up 800%.) My workaround was to pre-comp the illustrator layer, scale it up 800% inside the pre-comp, and then use that pre-comped layer at 100% in the main comp without “continuously rasterize” checked. No visible seam with Offset now.
