Activity › Forums › Adobe After Effects › Motion Tile on full res
Posted by Trevor Gent on January 29, 2010 at 4:34 amHi guys,
Having a new issue with Motion Tile.
Ive animated the center for a repeating tiled image that moves across the screen.
It seems to work fine when previewed or rendered at half resolution but if I try it on full res it seems to make the effect null and void and the image just sits there doing nothing.
Any ideas?
Thanks in advance.
Tommy Dimmel replied 11 years, 2 months ago 3 Members · 3 Replies -
Dave Johnson
January 29, 2010 at 4:30 pmDo you mean AE won’t render it at full-rez or it won’t preview it at full-rez? The two can be entirely separate issues.
If it won’t preview, maybe your machine just doesn’t have enough horsepower to RAM preview the effect at full-rez, but would render it just fine. Maybe try a 0+ RAM preview (skip frames), free up some RAM by closing other unrelated software you may be running, etc.
If it won’t render, are you not getting any errors messages via either pop-ups or error logs? Are you working at some gigantic screen size, with some funky codec, etc., etc.?
Trevor Gent
January 29, 2010 at 11:58 pmHi Dave,
Thanks for the response.
I really have no idea whats going on.
It stops working whether I ram preview (full) of do a full render (full res) but works fine on half or anything else.
I believe your RAM issue theory but Ive never had the problem before.
Im animating the motion tile center position and there is quite a bit of movement (100,000 units in Y) so maybe that where the RAM issue kicks in? I dont know… still doesnt make a lick of sense.
I redid the whole thing using rendered still frames and some expressions but Im still very curious as to why oh why motion tile stops working on full res.
Any further clues?
Thanks again
Tommy Dimmel
June 28, 2015 at 9:36 pmI’ve run into the same problem: trying to animate an image that moves along the x-axis, to simulate traveling through a tunnel. Just like you, everything worked fine until I tried to render at full resolution. I found a workaround, which may work for some of you. I made a YouTube tutorial for this. Hope this helps:
https://www.youtube.com/watch?v=K2OWfVr0Lus
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
