Activity Forums Adobe After Effects motion tile issue
  • motion tile issue
    Posted by Martin Robbins on June 26, 2017 at 6:21 pm
    Hopefully one of you people can help me out here.
    I am using motion tile to create a continuous road as if a car is driving, the perspective is as if from the drivers view. The car needs to pull over to the side of the road, to do this I used time remapping for slowing down and two position keyframes to move sidewards.
    All looks good in After Effects but when I try to export, the motion tile effect that gives the effect the car is moving, suddenly stops when I get to the timeremapping/position keyframes. I have tried various ways of pre-comping, swapping the position keyframes for motion tile – tile center keyframes,… but no luck.
    Any suggestions?
    I’m using CC 2017.2 on a mac pro, OS X Yosemite, processor 3ghz 8 core, memory 64gb, graphics AMD firepro d500.
    Look forward to hearing from you.
    Martin Robbins replied 9 years, 2 months ago 1 Member · 1 Reply
  • Martin Robbins
    June 27, 2017 at 10:48 am
    Hi Dave,
    Thanks for your response, unfortunately that didn’t work! Although I don’t know the cause, the workaround was to shorten the motion tiled clip from 20 seconds to 4, then duplicate that 4 second clip and keep repeating it.
