Activity › Forums › Adobe After Effects › Motion Tile Error
  • Motion Tile Error
    Posted by Brian Darwin on May 26, 2011 at 1:59 am
    Has anyone had this error before? “Motion Tile cannot allocate a buffer larger than 30000 pixels in either direction (516) (25::56)”? It comes up when I try to render my main comp (so it won’t render, but it WILL render at half resolution). Anyone have any ideas?
    Kevin Camp replied 15 years, 4 months ago 2 Members · 1 Reply
  • Kevin Camp
    May 26, 2011 at 3:15 pm
    motion tile increases the size of a layer, and the error is telling you that it has made the layer too large to fit into the image buffer (the image buffer is a memory buffer that has to hold all layers in order to render a frame… if you’re a gamer, it’s similar to texture memory on a graphics card).
    if it is occurring at a certain point in the render (say 100 frames in), the you might see if you can keyframe the motion tile setting at that point to decrease the size of that layer (or layers).
    if you can’t, then you may need to try to split that layer up into smaller pieces and layer them out so they look like one layer. if they need to animate as a single piece, then you can parent them to a null and animate the null.
    here’s an old link to some other tips for dealing with that error from generalspecialist.com (note, some may not apply to current versions of ae):
    https://generalspecialist.com/2006/11/avoiding-the-after-effects-error-could-not-create-image-buffer.asp
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
