Activity Forums Adobe After Effects Expressions Motion Tile and ‘time’ on one axis
  • Motion Tile and ‘time’ on one axis
    Posted by Kevin Olmsted on December 18, 2012 at 5:46 pm
    Hello all!
    I have an image that I want to scroll vertically in a comp. I also want it to ‘loop’ topp-and-bottom so I figured applying Motion Tile and moving the vertical amount of the ‘center’ parameter would do the trick. Instead of keyframing it, I would like to somehow apply the ‘time*’ expression to it, find a speed I like and then ‘set it & forget it.’
    Obviously, ‘time’ doesn’t work on that parameter as it has an X and Y axis. Is there any way to accomplish what I’m attempting? I know keyframing it would take about 3 minutes to find the speed I like, but I enjoy the challenge of finding solutions to these problems.
    Any help anyone can offer is greatly appreciated. Thanks!
    Avinash Ramanath replied 8 years ago 3 Members · 3 Replies
  • Ross Klettke
    December 18, 2012 at 6:44 pm
    Hey,
    This expression might be what you’re looking for:
    [value[0], time * 50]
    Like you said, because the Center property requires an X and a Y parameter, values need to be provided for both– so the above expression feeds “value[0]” into the X parameter and “time *50” into the Y. value[0] is the value of whatever you’ve keyframed the X parameter to be, so you can have “time *50” control the Y parameter and you can still keyframe the X value if you’d like.
    These can be changed to whatever you want.
    Hope that helps!
    –Ross
  • Kevin Olmsted
    December 18, 2012 at 7:23 pm
    That did the trick! Thanks so much!
  • Avinash Ramanath
    August 21, 2018 at 6:03 am
    Would you be able to help with an expression that loops on y-axis every 10 seconds?
