Activity Forums Apple Motion motion text output low quality?
  • motion text output low quality?
    Posted by Shaun Au on May 1, 2006 at 4:20 pm
    Hi, I created this title with Motion. However, the text in the final output looks very fuzzy. When I play it in Motion timeline, everything looks sharp and smooth. What’s going on? Thanks!
    Shaun Au replied 20 years, 4 months ago 2 Members · 2 Replies
  • Noah Kadner
    May 2, 2006 at 5:27 pm
    What are your export settings? And where are you judging the final quality?
    Noah
  • Shaun Au
    May 2, 2006 at 5:55 pm
    I found out what’s wrong with it. It’s the export setting. If I use “Lossless+alpha”, the text comes out sharp and smooth. I was using NTSC DV which is a compressed format. Thanks!
