Activity › Forums › Apple Final Cut Pro Legacy › Motion text looks like crap in FCP
Posted by Jason Jenkins on October 31, 2006 at 6:14 pmThis is an 8 bit uncompressed NTSC project. When I bring in Motion projects (whether they are animated or not) the text looks like crap (jagged edges, crawling on the animated ones). Some setting I’m missing?
Jason Jenkins replied 19 years, 9 months ago 8 Members · 18 Replies -
Boyd Mccollum
October 31, 2006 at 6:30 pmnormally this is an issue of viewing the text on your cinema display. Have you taken a look at them on an external NTSC monitor?
Jason Jenkins
October 31, 2006 at 6:36 pmSorry, I should have mentioned that I’m viewing a fully rendered timeline on a Panasonic BT-LH2600W via Kona component output. The fonts aren’t thin and wimpy either–we’re talking Arial Black here.
Ron Dylewski
October 31, 2006 at 6:52 pmDoes positioning the titles at an even integer apply in this case?
It solves a lot of problem when using the built-in Boris titler…Ron
Photos, news, memories and musings on the great American Roadside experience
https://www.theamericanroadside.com
Are you a collector? Put your collection online for free at What A Collection.com!
https://www.whatacollection.com -
Thaxter Clavemarlton
October 31, 2006 at 7:08 pm[overeasy] “Does positioning the titles at an even integer apply in this case?
It solves a lot of problem when using the built-in Boris titler…”That’s not only true of the Boris Titles, but with the positioning of ANY kind of video or graphics.
Tom Brooks
October 31, 2006 at 7:13 pmWhat are your Motion project settings? Do they match FCP sequence?
James Sullivan
October 31, 2006 at 7:20 pmI do not know if this applies to Motion but FCP does not interpret the Alpha channel right. Perhaps you have to switch it to Strait instead of Black or the other way around.
James
Jason Jenkins
October 31, 2006 at 7:35 pmI just double checked the render settings. It is fully rendered.
