Activity Forums Apple Motion Motion templates – limit on text size? alignment problems?
  • Motion templates – limit on text size? alignment problems?
    Posted by Joe Mcneilly on December 9, 2010 at 10:01 pm
    I have a Motion template with a large Number right in the middle (using it for a countdown). Naturally, I want it to be a dropzone, and reuse it throughout the Final Cut edit. So in the Motion project, it is sized at 544 points. But when I bring the template into Final Cut, the size seems to max out at 288, and the number is all out of alignment, nowhere near where I placed it in Motion. Has anyone else had this problem or know how to fix the template so I get consistent results?
    Otherwise, I suppose I could just render dumb .movs for each number…But I want to be able to deploy changes quickly across the entire project. Suggests?
    Mark Spencer replied 15 years, 8 months ago 2 Members · 3 Replies
  • Mark Spencer
    December 9, 2010 at 10:03 pm
    Instead of increasing the font size of the text in Motion, increase the scale (Properties tab).
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Joe Mcneilly
    December 9, 2010 at 10:09 pm
    I’ll give that a shot. Hopefully the text will stay crisp! Thanks for the suggestion.
  • Mark Spencer
    December 9, 2010 at 10:27 pm
    Text is vector, it will stay crisp at any size – providing you set the render quality to Best – do it in both Motion and FCP (sequence settings – render control tab).
    Mark Spencer
