Activity Forums Apple Motion Motion Template not working
  • Motion Template not working
    Posted by Michelle Orpe on August 16, 2011 at 6:59 pm
    Hi
    I just bought a motion template from motionvfx but when I open it in motion and try and play it, it won’t play and when I try and change the text or drop pictures in the drop zone it is just very slow and then doesn’t work properly. The template is for Motion 4 and I have Motion 4, does anyone know what I am doing wrong?
    Michelle
    Michelle Orpe
    http://www.michelleorpe.com
    Michael W. towe replied 15 years ago 4 Members · 4 Replies
  • Jerry Wise
    August 16, 2011 at 7:31 pm
    which template is it?
  • Stephen Smith
    August 16, 2011 at 7:54 pm
    I have found that templates can be big files and because of that they will play back sluggish. What happens when you change the text?
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Michelle Orpe
    August 16, 2011 at 9:02 pm
    It is project_401 from motionvfx.com although I managed to put in all the pics in the drop zones and I managed to change the text (even though it took ages and I had to wait a minute after I did anything for it to catch up) when I thought it was good enough I saved it and imported it to FCP, when I tried to play on viewer it did nothing other than a couple of stutters but I dropped it into the timeline and rendered it (which took ages) but after that it works fine.
    So good news is I got it to work but it was a nightmare and I can’t watch my work back in motion I have to save and import and render which is a lot of time to then see I have made a mistake and have to do it all over again.
    Not sure if that is the only way or if I am doing something wrong
    Mich
    Michelle Orpe
  • Michael W. towe
    August 22, 2011 at 2:25 am
    Looks to be a fairly complex template with lots of blur and lighting effects going on. Chances are it’s just taxing your system quite a bit which is causing the slow down. You can try setting the render to “draft” while working on it, and even cutting the resolution to 1/2. This might cut down the stuttering a bit while working on the project. However when rendering at full res your still going to be stuck with the long render times, it’s the nature of the beast when working in complex projects.
    Mike
    Michael W. Towe
    President M2 Digital Post
    http://www.m2digitalpost.com
