Activity › Forums › Apple Motion › motion template change from 486 to 480
Posted by Scott Patterson on April 30, 2010 at 8:44 pmwow, just wasted over two hours trying to figure out why Motion templates will only open in 720 by 486. When used in FCP they have to re-render and looks terrible. Went to project presets over and over and 720-480 is selected. Tried a variety of workarounds.
Basically how can I open a template and use in FCP at the normal 720-480.
Bet this is an easy one..sorry just can’t seem to figure it out.
thanks
scottMark Spencer replied 16 years, 4 months ago 3 Members · 6 Replies -
Mark Spencer
April 30, 2010 at 8:49 pmNot sure what you mean. Different template themes are available in different resolutions and frame rates – in the Template Browser, you can use the pop-up menu at the top right to filter them by HD, NTSC, and PAL. If you choose an HD template, it will be HD – but you better first make sure your sequence settings match the setting of the template before you edit it into the sequence otherwise it will be scaled to fit the sequence.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Stephen Smith
April 30, 2010 at 9:03 pmPlacing a Broadcast SD 720×486 should look great in a 720×480 timeline. All it does is cut of the 6 lines you don’t need. In FCP go to Sequence, Settings, Render Control and set Quality to Normal. Hope this helps and best of luck.
Check out my Motion Tutorials
Scott Patterson
April 30, 2010 at 9:03 pmi want a 720 by 480 motion sequence, which I think it is since it says so in the preferences project settings. but whn I bring into fcp it is still 486.
Mark Spencer
April 30, 2010 at 9:21 pmYou need to check the setting for your current sequence, NOT for new sequences you create. Select your current sequence and go to Sequence > Settings.
Mark Spencer
Mark Spencer
April 30, 2010 at 9:23 pmOh, and when you say it looks terrible, could be many factors there:
1) Are you evaluating the quality in FCP’s Canvas? For a DV sequence in particular, you can’t. You have to use a broadcast monitor
2) Did you adjust the settings for rendering Motion projects in FCP? Sequence > Settings > Render Control tab
Mark Spencer
