Activity › Forums › Apple Final Cut Pro Legacy › Motion Tab (Easy Question)
  • Motion Tab (Easy Question)
    Posted by Michael Allen on November 6, 2008 at 10:10 pm
    When I highlight a clip in the timeline, I can go to the motion tab and move the object with keyframes with no problem. But, if I highlight several clips, how can I make a move using the keyframes. I am sure this is simple, but I can’t figure it out.
    Thanks in advance,
    Mike
    Andy Mees replied 17 years, 11 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    November 6, 2008 at 10:17 pm
    Make the change(s) in the Motion Tab on the first clip.
    Select (highlight) that clip on the timeline.
    Copy (Apple-c) that clip and then…
    Select any and all of the other clips you want to change (to match changes made on the first clip.
    Paste (Apple-v) on the other clip(s) and the same Motion will be applied.
  • John Fishback
    November 6, 2008 at 11:36 pm
    Don’t you mean paste attributes which is option-v? Then you select which attributes you want affected from the dialogue that pops up. In this case Basic Motion. This will make the 2 clips move exactly the same way.
    However, if the object is to move a number of clips relative to each other, then you should nest those clips and then move the nest.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
    November 7, 2008 at 11:07 am
    [John Fishback] “Don’t you mean paste attributes which is option-v?”
    You know I do. Thanks for the save!
    Paste Attributes (option-v) and check the boxes of the changes you want to “paste” the the same Motion will be applied if you choose “Basic Motion.”[John Fishback] “Don’t you mean paste attributes which is option-v?”
  • Andy Mees
    November 7, 2008 at 1:19 pm
    Mike
    You can’t directly apply motion to act on a group of clips as a single entity (although you can apply the same parameters to each member of a group) .. what you can do tho, is to nest those items first (Opt – C) and then apply the motion to the nest
    Hope that helps
    Andy
