Motion Style Stroke Keyframe Limitations
I have discovered that you can animate the stroke but so far I have found no way to animate the stroke while it is pulling from the shape style menu.
Here is what I did.
1. created 2 full screen horizontal strokes
2. key framed the strokes using the first point offset option
3. played the animation ( it did what I was expecting )
4. choose the floral > Vine 3 from the shape style menu
5. I played the animation again and the animation was gone (keyframes disappeared from the keyframe editor)I have tried to animate the plain default stroke and it will animated.
I have tried animating the styled stroke and it only worked for the write on. (would not allow it for the write off)
I have tried 2 other styled shapes and they do the same.
I have trashed prefs.Is there a rule to this?
Is there a key combo that could have been pushed to disable this?
Why does the animation become void once I choose a shape style?I have decided to scrap the wipe since it is taking longer to create it than it took to edit the piece. It is also due at 4pm eastern time. I will just pull something from my ETK pack.
Knowledge + Action = Wisdom
