Activity Forums Boris FX Motion Stabilizer Assistance
  • Peter Mcauley
    December 20, 2011 at 1:14 pm
    Hi Bryon,
    When you have the preview monitor open for the motion tracker, do you see the search and target regions as displayed in the tutorial clip? If so, did you click on the analyze button in the control panel and if you did this, did you see the trackers in motion as they locked on to the target?
    Cheers,
    Peter.
  • Byron Kawane
    December 25, 2011 at 4:40 am
    Thanks Peter, I think I kind of figured it out. I moved the video event below the effect and the trackers appeared.
    Still not sure what all the other controls are and how they are used. There’s NOTHING on the web or in the online documentation.
    Is there a better more detailed tutorial, .pdf or manual of all the controls?
    I ended up using Mercalli stabilization, much better result and straight forward.
