Activity Forums Apple Motion Motion Snow Particles
  • Motion Snow Particles
    Posted by Andrew Wood on April 15, 2008 at 3:59 pm
    Hi
    I am using the motion snow particles, but i want to animate them so they stop on the ground at the bottom of the frame and start building up, im sure there would be a way of doing this, i just cant seem to work it out!!!
    Any help / suggestions would be much apprecited,
    Thankyou
    Andrew Wood
    Burt Hazard replied 18 years, 5 months ago 2 Members · 1 Reply
  • Burt Hazard
    April 17, 2008 at 2:49 pm
    You’ll probably have to use a cheat, i.e., create an animated white shape on the bottom of your screen (or multiple shapes if you want the “snow” to accumulate on different objects in your comp). (The snow presets use Random Motion bahvior, so even if you use aan additional drag behavior, the particles will still “dance” around a bit.)
