Activity Forums Adobe Premiere Pro Motion Smoothing in Premiere Pro
  • Motion Smoothing in Premiere Pro
    Posted by Dennis Dean on January 24, 2018 at 7:16 pm
    I’m relatively new to Premiere Pro and looking for a way to smooth motion across keyframes. I’m trying to animate a graphic object (in this case a png of a cartoonish frog) to jump across the screen in an arc. From lilypad to lilypad.
    I have a starting keyframe, a middle keyframe at the apex, and an ending keyframe. So the frog jumps up and down at more-or-less a right angle.
    Several years ago Curt (CWRIG) wrote: “iN 6.X you can use the motion tool and it has a “Smooth” option. If you make 4 keyframes in a square and set it to the Smoothest option you will almost get a circle.”
    I think that’s what I’m looking for but cannot find.
    Any pointers would be helpful. Thanks!
    Dennis
    Dennis Dean
    The Dean Group
    We’ll help you get your story out!
    http://www.deangroupmedia.com
    Jeff Pulera replied 8 years, 6 months ago 2 Members · 1 Reply
  • Jeff Pulera
    January 24, 2018 at 8:39 pm
    Hi Dennis,
    In Effects Controls panel, right-click on any keyframe (diamond) and play with changing the Spatial Interpolation and Temporal Interpolation, using Bezier options to see if you get the desired results.
    Jeff
    Jeff Pulera
    Safe Harbor Computers
