Activity Forums Adobe After Effects Motion Sensing
  • Motion Sensing
    Posted by Tyler Britton on November 1, 2009 at 3:05 am
    Hey I have a question. Is there any way to reveal something in AE that is only moving, like seeing movement only and the still background is like masked out. Anyone get what I am trying to say?
    Eric Woods replied 16 years, 10 months ago 3 Members · 2 Replies
  • Erik Waluska
    November 1, 2009 at 4:53 pm
    You can use a difference matte effect. Put your static background layer under the layer with movement and switch the moving layer to “difference” blending mode. It will only show the pixels that are different in the two layers.
    -E
  • Eric Woods
    November 3, 2009 at 10:09 pm
    This works, but only for limited applications. The problems come when a pixel that is part of the moving object is exactly the same as one on the still background. Then you will have a transparent pixel in your moving object. Also you need to have a very good quality camera because if there is any slight lighting change in the Background or any artifacts that pixelate, you will have holes in what is supposed to be your BG Matte. Either way you might end up doing a decent amount of rotoscoping.
    Eric Woods
    https://EricWoodsFX.com
    EricWoodsFX.com
