Activity Forums Adobe Premiere Pro Motion->Scale to 90% results in blurry image
  • Motion->Scale to 90% results in blurry image
    Posted by Zubalea on June 7, 2006 at 4:15 pm
    Hi Gang,
    I have a DV clip that I scale to 90% using Motion->Scale (Uniform Scaling) in Premiere Pro 2.0. The image becomes blurry.
    I take the same clip and scale it down to 90% in After Effects 7.0 Pro and the image remains clear.
    Is there something I am missing? Why is premiere making the image blurry?
    Mike
    Zubalea replied 20 years, 3 months ago 2 Members · 2 Replies
  • Tclark
    June 7, 2006 at 8:27 pm
    I have the same problem not only with scaling but also rotation.
    I found that using the transform plugin effect from the effects folder does a better job then the FIXED transform options in the effects panel.
    Let me know if this helps when you try it.
  • Zubalea
    June 8, 2006 at 1:09 pm
    I have tried with the transform filter also and got the same results.
    Thank you.
