Activity Forums Apple Motion Motion rasterizing – how to use Blend modes?
  • Motion rasterizing – how to use Blend modes?
    Posted by Bob Woodhead on October 23, 2017 at 10:58 pm
    So Motion rasterizes groups when filters, masks, etc are applied. This in turns “kills” Blend modes (multiply, darken, etc). So I’ve got a project where I need to use blend modes in a group and then apply a blur. Fail.
    What’s the workaround?
    Simon Ubsdell replied 8 years, 10 months ago 2 Members · 2 Replies
  • Bob Woodhead
    October 23, 2017 at 11:50 pm
    …. and here’s the solution:
    Clone the group and apply the filter to the clone. The Rasterization “mark” should disappear from the Blend Mode of the Clone. [If the group visibility check mark is still on – turn it off/uncheck it.]
    Thanks to fox_m over on Apple Forums!
  • Simon Ubsdell
    October 26, 2017 at 11:13 am
    [Bob Woodhead] “So Motion rasterizes groups when filters, masks, etc are applied.”
    This is not correct. It is not rasterising. Here’s a simple test to prove it.
    Create some very small text. Apply a filter to the enclosing group. Scale the group as large as you want. You will not see any degradation of the text.
    What does rasterise a group is hitting the Fixed Resolution button.
    What does happen however is that applying filters to a group changes the overall Blend Mode to Normal as against the default of Pass Through.
    So for example, if you have a layer in your group that is set to Screen and you apply a filter to the group, you will need to reset the Blend Mode of the group itself to Screen.
    Edit: A few filters do indeed rasterise the group, but the majority do not. The point remains that it’s not “rasterising” that causes the Blend Mode to change from Pass Through to Normal.
    Simon Ubsdell
    tokyo productions
    hawaiki
