Activity Forums Adobe After Effects Motion Paths
  • Motion Paths
    Posted by Matthew Krumins on March 18, 2008 at 9:39 pm
    Hi All,
    How can I make a particle Producer follow a path I’ve created with the mask tool? Or have I gone about this in completely the wrong way?
    Any help would be appreciated.
    Cheers, Krumo
    Matthew Krumins replied 18 years, 6 months ago 2 Members · 2 Replies
  • Bob Root
    March 19, 2008 at 12:20 pm
    In your timeline, highlight mask shape and copy it. The mask can then be pasted to your particle generator by highlighting the x,y position and pasting.
    If you’re using Particle Playground, the position is found under the Cannon twirl down. If you have the Particular plugin, you can find the position under the Emitter twirl down.
    Good Luck. Hope this helps.
    Bob
  • Matthew Krumins
    March 19, 2008 at 9:26 pm
    Thanks Bob Much appreciated!
