motion path scale increase will not copy to null for particular
Hello all, I have an issue.
I have a series of motion paths in photoshop that when copied into my comp are a lot smaller that the comp size. I am copying the path details to a null that particular is using to create light beam movement.
the thing is that I have created quite a few already and the new set that I have (the small ones) were done by someone else.
I have increased the scale of the masks, which are all in one shape layer but when I copy the mask path to the null it reverts to the original size.
the object is a man, and is broken down to left, right, head, left leg, light leg so when scaled they all have to fit together.
There has to be a way of increasing the overall paths scale to then copy the individual parts without having to then manually scale them up
help help help.
