Activity Forums Adobe After Effects motion path following a mask
  • motion path following a mask
    Posted by Mike Weber on September 21, 2005 at 5:49 pm
    In AE 6.5, I want to have a picture follow a path, specifically a circular path.
    I’ve done this effect before in AE 5.5, using this strategy:
    1) Make a new solid layer. Create a circle shaped mask. Hide the layer. Click on the mask and copy (command-C)
    2) On my layer with the picture, open up the Transition settings, highlight the Position setting, and then paste (command-V) the mask. Automatically, new position keyframes are created, and the picture is set up to follow the circle mask’s path in a 2 second period. I adjust from there.
    I’m now using AE 6.5, and am trying to do the same exact thing. However, in AE 6.5 when I paste the mask, it just applies the mask to the whole layer, and doesn’t affect the position at all. I checked the manual, and it still seems to suggest doing it the old way, the way that worked in AE 5.5. Can anyone tell me what I need to do?
    thanks very much
    Mike Weber
    Mike Weber replied 20 years, 8 months ago 3 Members · 4 Replies
  • Dan Ebberts
    September 21, 2005 at 6:00 pm
    Just click the position stopwatch to create a keyframe, then paste.
    Dan
  • Roland R. kahlenberg
    September 21, 2005 at 6:30 pm
    You will have to select either the keyframe or the i-beam of the mask shape property for this to work. And as Dan suggested, you will also have to select the position parameter’s keyframe or I-beam before pasting. There was some change but I can’t recall if it was implemented in 5.5 or 6 or even 6.5
    Cheers
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Mike Weber
    September 21, 2005 at 7:35 pm
    >>>Hey, Mike…Four letters: k-c-r-g. Ring any bells?
    Hello Dave
    I’ve heard of KCRG in Cedar Rapids because I went to school in Iowa City a long time ago. But I don’t believe we’ve met. Or have we???
    Mike
  • Mike Weber
    Thanks guys – I’ll give this a try
    Mike
