Activity › Forums › Apple Motion › Motion path behaviour not, er, behaving.
  • Motion path behaviour not, er, behaving.
    Posted by Gareth Randall on November 12, 2015 at 10:48 am
    I’m building a project involving a karoake-style bouncing ball hopping over the lyrics to a song. Very easily done with a Bezier shape to define the path and the motion path behaviour set to “custom” speed, with speed keyframes on every bounce point.
    My problem is that I can only do the first line of the song. When I try to animate the second line, I do everything the exact same way, but the motion path behaviour stops working. I apply the geometry, set it to “custom”, and then when I move the speed slider the ball doesn’t move with it. I can make the ball move with the “offset” slider, but that’s all.
    Note the screengrab. This is what happens when I add the second motion path behaviour and then set the speed to “custom”. The keyframes appear in empty space to the right of where they should be. Dragging them back into the correct relationship with the motion path behaviour does not fix the problem.
    As of now, my only option appears to be build each line in a new project starting at 00:00:00:00 and then join them all together after they’re rendered out.
    EDIT – just tried that. New project, same problem – ball not responding to movements of the speed slider. I’ve trashed the prefs and will try again…
    Robin S. kurz replied 10 years, 10 months ago 2 Members · 1 Reply
  • Robin S. kurz
    November 13, 2015 at 10:14 am
    Not sure what’s going on there, but I also once did something similar and simply used my Wacom to draw the animation in realtime on playback with the active record button. Much more “organic” of course, but VERY quickly done and always editable after the fact if needed.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
