Activity › Forums › Adobe After Effects › Motion Path – Along dashed lines
  • Motion Path – Along dashed lines
    Posted by Ohki Komoto on February 27, 2009 at 9:48 pm
    Hey everyone, new to the forums and pretty new to after effects but I’ve dived in head to toe.
    I have a simple problem, that I have not figured out, I understand using masks for assisting in motion tracking, but in this instance I don’t have that luxury.
    I created a simple dashed line, with the pen tool, and added “trim paths” so I could control the dashes moving along. I want an object to follow this path, like a plane on a moving map.
    Thanks for any help and sorry if this is such a dumb question, i’ve looked around and tried a few things, but no luck. I’m sure its a 2 sec solution
    Ohki
    Ohki Komoto replied 17 years, 7 months ago 3 Members · 3 Replies
  • Paul Hennell
    February 27, 2009 at 10:24 pm
    If you highlight the path and use edit copy, you can then paste it as a motion path on the position property of your object.
    Note – you need to select the Path not the whole shape layer, and your destination object must have a position key frame already applied.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Simon Bonner
    February 28, 2009 at 5:46 am
    Hi Ohki,
    You might find my animated map tutorial useful.
    I think Aharon also made a tutorial on a similar topic here at the cow a while back. Scroll through the AE podcast page and you’ll see it.
    Simon Bonner
    youtube.com/simonsaysfx
  • Ohki Komoto
    February 28, 2009 at 4:43 pm
    Thanks Paul and Simon. I knew it would be something very simple, I just somehow didn’t interpret that single keyframe in the paths to be all the motion created by the pen tool.
    Thanks so much!
    Ohki
