Activity Forums Apple Motion motion path…
  • motion path…
    Posted by Adam Heayberd on February 22, 2011 at 9:54 am
    Hi
    I need a pointer on creating a motion path. I need a flag to come in behind a subject within the first 10 frames at high speed, coming in from left (off camera) to right, ending behind the subject and staying there for a few seconds, then to fly off to the right off screen within the last 20 frames.
    Im having a nightmare of a time trying to get the motion path right and need some pointers!!!
    Many thanks.
    Adam
    Editor & Self Shooter in the UK
    Zak Peric replied 15 years, 6 months ago 2 Members · 1 Reply
  • Zak Peric
    February 22, 2011 at 5:25 pm
    You can not achieve this with behaviors, however this is a simple animation that can be key-framed easily.
    Go to the properties of your object and animate the position parameter of the object. Then in the key-frame editor you can change the interpolation of the animation.
    Good Luck
