Activity Forums Apple Final Cut Pro Legacy Motion Not Seeing Alpha Channel From FCP Export
  • Motion Not Seeing Alpha Channel From FCP Export
    Posted by Haplessjoe on January 20, 2006 at 10:13 pm
    I have a basic video in Final Cut that uses an alpha channel that I’d like to bring into Motion. I export using Quicktime conversion, Animation codec with “Millions+”. I then bring in the clip into motion, but am left with all “alpha” areas filled in with black. I attempted to manually adjust the Media settings in case Motion was improperly “guessing” the alpha channel, however this provided no solution. This is a method I could have sworn I’ve used successfully in the past, but now I’m getting no results.
    I’m able to achieve a similar effect by laying down a green matte under the video in Final Cut and then applying a “Color Key” and “Desaturate” filter combo in Motion, but the jagged edges this produces leaves much to be desired.
    Any help is much appreciated. Thanks!
    (x-posted to Motion forum)
    Kevin Monahan replied 20 years, 8 months ago 3 Members · 2 Replies
  • Bret Williams
    January 21, 2006 at 12:52 am
    Not sure about the current version, but in the past the only way to export an alpha channel from Final Cut was to turn off layer 1, which always fills with black.
    So, move everything onto layer 2 and above and turn off layer 1. Then export as you did.
  • Kevin Monahan
    January 22, 2006 at 12:25 am
    No, the way you do it is to NOT render before exporting.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
