Activity Forums Apple Motion Motion Not Opening
  • Motion Not Opening
    Posted by Luke Price on February 15, 2011 at 11:24 am
    I have just replaced my old Mac Pro with an 8-Core (2×3.2 Ghz Quad Core Intel Xeon with an ATI Radeon HD 4870). I had recently bought a new Hard Drive for my old machine which I had a clean 10.6 install on and then added FCS 3. FCP is working fine but Motion will not open at all. I get to select what format I want to work in then it crashes before opening any Motion windows.
    I have trashes preferences, re-installed and done software updates to no avail.
    Your suggestions would be greatly appreciated.
    Luke Price replied 15 years, 7 months ago 3 Members · 3 Replies
  • Jeff Greenberg
    February 16, 2011 at 6:23 am
    You said you did a clean install and then added FCS3.
    Did you do all your software updates? HOw how about repaired permissions? Did you migrate anything from the prior machine?
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Anders Larsen
    February 16, 2011 at 10:27 am
    As I read this you moved the hard drive from your old Mac to the new one – correct?
    In theory this should work just fine with MacOS X (and it sometimes does), but in reality you are setting yourself up for a world of hurt.
    Do you have an empty drive in your system? If so, try doing a clean install of OS X and FCS on that and boot from it. If that works, I’ll bet you that the problem stems from moving the drive over.
  • Luke Price
    February 17, 2011 at 2:59 pm
    Thanks for help guys.
    I did the updates and permissions Jeff, then migrated some non-FCS stuff across.
    Anders, it would seem I’m looking at a whole clean install – arrgg!
    Well better safe than sorry I guess.
