Activity › Forums › Adobe Encore DVD › Motion Menu render problem and button highlighted prematurely
  • Motion Menu render problem and button highlighted prematurely
    Posted by Bob Cole on June 30, 2005 at 5:37 pm
    (sorry if this is a twice-read for you but I got no responses so I assumed it got lost in the other thread)
    I originally asked about how to position buttons whose location was dictated by a video that I was using as background for a motion menu. (The video starts out without buttons, so their position wasn’t apparent within Encore.) The proper answer was to use a shorter clip or a PS frame, and create the buttons in Photoshop. I did that.
    I was able to position my buttons in Photoshop using a shorter version of just the tail end of the motion video. In Encore I substituted in the full length motion video (which starts off without button).
    When I try to render the motion menu, it is grayed out, both on the File dropdown menu and in the Preview window.
    So I tried burning the DVD. The motion menu plays, but the first button is already in its highlighted state.
    I’d appreciate any ideas about this, and also any suggestions as to a good tutorial for motion menu creation (again, I don’t have the latest version of After Effects).
    — BC
    Joe Bowden replied 21 years, 2 months ago 2 Members · 3 Replies
  • Bob Cole
    June 30, 2005 at 7:51 pm
    Is it true that Encore shows the highlight state for Button One, regardless whether you select “Default Button” to “none” or any of the buttons?
    My workaround is to create a “dummy button” and name it #1. Does that sound right?
    — BC
  • Bob Cole
    July 2, 2005 at 11:05 am
    [Bob Cole] “My workaround is to create a “dummy button” and name it #1. Does that sound right?”
    Found out that the dummy button is a bad idea, as hitting “play” when it is invisibly selected may cause user trauma.
    Much simpler: reduce the transparency (menu/edit menu color set) of the Selected state to 0%, so the single button on the menu doesn’t appear to be highlighted.
  • Joe Bowden
    July 5, 2005 at 5:17 pm
    Did you set your Loop Point value?
    The button highlighting should come on at the Loop Point timecode.
