Activity Forums Adobe After Effects motion math
  • motion math
    Posted by Eric on September 3, 2005 at 1:49 am
    is there anything similar to motion math in ae 6.5….i need to use layer audio…..any ideas???
    thanks for any help..
    er
    Eric replied 21 years ago 2 Members · 2 Replies
  • Colin Braley
    September 3, 2005 at 3:16 am
    Nope motion math no longer exists but you can use the “convert audio to keyframes” assistant the comes with AE. It will create a null layer which has the sliders the represent the audio ampliture of the left channel only, the right channel only, and of both channels. If you need a more detailed solution check out trapcode’s “sound keys” plug-in which allows you to acess the volume of different ranges of sound.
    ~Colin
  • Eric
    September 3, 2005 at 4:34 am
    cool, thanks./
