Activity Forums Apple Final Cut Pro Legacy motion master templates on FCP 7.01
  • motion master templates on FCP 7.01
    Posted by Gabriele Girardi on October 28, 2009 at 12:57 pm
    hallo everybody,
    on FCP 7.0.1 when i select master templates in the viewer (any kind, hd sd ecc)
    it seems load it but after a few seconds i see a white screen no images, nothing..
    anyone knows what is the problem?
    Mark Palmos replied 16 years, 10 months ago 4 Members · 12 Replies
  • 12 Replies
  • Tom Wolsky
    October 28, 2009 at 2:03 pm
    Works for me. Are the templates in the standard location? Is the viewer set to RGB or alpha?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Gabriele Girardi
    October 28, 2009 at 4:34 pm
    viewer is in RGB
    where is the correct location?
    Gabriele Girardi
    FCP_Editor
  • Tom Wolsky
    October 28, 2009 at 5:11 pm
    The default location is Hard Drive/Library/Application Support/Final Cut Studio/Motion
    All the best,
    Tom
  • Gabriele Girardi
    October 28, 2009 at 5:32 pm
    thanks a lot for you help,
    but i does not work…
    it seems to load the template ‘cos i can work on the controls of template
    but it gives me only the white screen.
    another think i notice is that when i was working with FCP 6 it was not a problem
    and i could even open the .motn files with Quicktime!!
    now i can’t?
    how do you explane that?
    when i try to open motn files it gives me error, i think it’s abug of quicktime X
    talk soon
    thank you
    Gabriele Girardi
    FCP_Editor
  • Tom Wolsky
    October 28, 2009 at 5:37 pm
    What OS and QuickTime versions are you using?
    All the best,
    Tom
  • Gabriele Girardi
    October 28, 2009 at 5:45 pm
    OS X Snow Leopard (10.6.1)
    Quicktime 10.0 (51)
    thanks
    Gabriele Girardi
    FCP_Editor
  • Tom Wolsky
    October 28, 2009 at 6:02 pm
    Did you do a clean erase and install of the OS?
    Try opening the templates in the QuickTime 7 player, not the QT X player.
    All the best,
    Tom
  • Gabriele Girardi
    October 28, 2009 at 6:13 pm
    i just did an upgrade. did not erase anything
    i just opened a motn file zith quicktime 7..!!!
    i have to do i clen installation of snow leopard?
    thank you
    Gabriele Girardi
    FCP_Editor
  • Tom Wolsky
    October 28, 2009 at 6:27 pm
    New operating systems need a clean erase and installation and full reinstall of the software. You should not update to a new operating system with the pro apps.
    All the best,
    Tom
  • David Chai
    October 29, 2009 at 5:00 am
    I’ve seen this problem on a friends Quad Core macpro. 10.5.8, QT 7.6.4, FCP 7.01. Template opens fine in Motion but is always a white screen in FCP. Video is fine, only Motion Templates are a probIem. I suspect its to do with either not enough memory, only has 3GB, or the graphics card, ATI 2600 in this quad core machine. 8 core machines don’t seem to have any issue. Another quad core with 1900XT is also ok, but it also has 11GB of RAM.
    David Chai
    Director . Camera . Editor
    http://www.davidchai.com
    dc@davidchai.com
    212 363 0159
