Activity Forums Apple Motion motion master template font correction
  • motion master template font correction
    Posted by Steve Ascher on March 19, 2010 at 4:24 pm
    We’ve been trying out using a motion master template to generate subtitles for a FCP project and like the idea that you change font or drop shadow in the master and have it update all the subtitle clips in the FCP timeline that you’ve already made.
    But we’ve tried reopening the master template in motion, changing font SIZE, saving then returning to FCP and it doesn’t seem to affect the font size of the existing timeline titles. Is there a way to do this? Is this attribute disabled because it’s one of the things you CAN change on individual clips using the motion tab in FCP?
    Mark Spencer replied 16 years, 6 months ago 2 Members · 3 Replies
  • Mark Spencer
    March 19, 2010 at 4:30 pm
    If you bring that new template into your browser, then drag it onto an existing template in your sequence and wait a beat, you’ll see a drop menu with several options for replacing that template, all templates in the sequence, or all templates in the project.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Steve Ascher
    March 19, 2010 at 4:40 pm
    Thanks, Mark. BTW, your tutorials are really wonderful and have helped us a LOT.
    we’ve been modifying subtitle clips by selecting one and sending it to editor, modifying the master and saving. That works for everything but font size.
    Are you saying it’s better to just open the master independently, change font size and re-import into FCP? If you do that and drag it onto an existing clip, will it try to overwrite the existing text or just change font size?
  • Mark Spencer
    March 19, 2010 at 4:45 pm
    You should be able to adjust the font size directly in FCP in the template controls.
    The drag and drop method should just replace the style, not the content.
    Mark Spencer
