Activity › Forums › Adobe After Effects › Motion Masking
  • Motion Masking
    Posted by Alexander Jones on September 15, 2007 at 3:15 pm
    Hello everyone,
    I posted a while ago asking if it was possible for After effects to see what was moving and draw a mask around it. Somebody responded to say ” Only if you have professinal”, I do have Professinal and was wondering if anyone could tell me how to do it.
    Gon Perdigao replied 18 years, 6 months ago 3 Members · 2 Replies
  • Mike Clasby
    September 15, 2007 at 5:18 pm
    1) Here’s a Script. It works as good as the track you get:
    https://del.icio.us/escruz/Rotoscope
    Download, then copy/move the jsx file RotAE.jsx to AE’s Script Folder, then open AE.
    Select the layer with the Mask, File>Run Script>RotAE.jsx. Then select the Mask again, and in the control panel that popped up, hit “Apply Tracker”, and you’ll have as many track points as you have mask vertices.
    Run you Motion Track. The mask will be as good as the motion track so you may have to adjust points by frame like you mentioned in Aharon’s tut.
    Now twirl down the layer, select the Tracker 1 (above the mask points) and also select the Mask, then up in the Script’s Control panel, click ” Apply Mask”. You should be good to go.
    You can still move individual mask points if the track wasn’t great, or adjust the bezier handles as needed, as the script just set mask Shape keyframes at each frame.
    2) There is another script, “rotoTool”, I haven’t really used it yet, but his stuff is great. Here’s the script:
    https://www.nabscripts.com/Downloads/downloads_en_3.php?id=1
    His site is French and some of the scripts a low on translation, but the Help “?” in the script panel that pops up is very friendly, English, and looks very straightforward, yet versatile. It converts tracks to masks, or reverses tat converting masks to tracks.
    Lots of other interesting scripts there too.
  • Gon Perdigao
    March 14, 2008 at 2:55 pm
    hi there i used this script.
    It works but when i do the aply to convert the trackpoints into the mask it appears this error
    after effects: not enough memory to creat list.
    (2k requested, 4476k available)
    (27 :: 30)
    i have a quadcore with 4gb of memory, i don’t think that is really lack of memory.
    Can anyone help me
