Activity Forums Adobe After Effects Motion Logo for Cinema //…Light Flickering..
  • Motion Logo for Cinema //…Light Flickering..
    Posted by Mohit Woody on January 11, 2008 at 11:16 pm
    HI guys… i need some help here,
    1. i am making a motion logo for a movie production house, so the logo will be shown on the big screen,70mm my question is, what should be my composition resolution???
    i have done this before but for small screen, Pal/ 720×576
    but i am not aware , for cinema. pls advise..
    secondly..
    i wanna make a light flicker, i cant recall how to do this using expression… its something like adding expresison to intensity param, i am using wiggle (5,10) … does not work..!!! i think i am typing wrong command… any help pls??
    Rich Seemueller replied 17 years, 8 months ago 3 Members · 2 Replies
  • Darby Edelen
    January 12, 2008 at 5:16 am
    [lowpolymodel] “wiggle (5,10)”
    If you’re typing a space between ‘wiggle’ and ‘(5,10)’ you shouldn’t be:
    wiggle(5,10);
    If you’re going to a 70mm print then you’re dealing with a very large amount of data. I have no experience working with such a large format, but I would guess that you wouldn’t want to work with less than a 4K resolution (4096 x 3112)… 2K should work for 35mm.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Rich Seemueller
    January 8, 2009 at 3:21 pm
    the wiggle expression is what i always use when doing this effect. i usually set my wiggle amount for more than that, though. i think i usually set it at around 30 or 40, and then make the initial value 30 or 40 less than the max i want. (obviously you want those 2 values to be the same.)
    also, i don’t think that the space really matters. (at least it doesn’t in my AE.)
    i’m wondering if your rate is high enough and your value is low enough that you’re not really seeing the effect.
    just a thought.
